First off, I'm sorry to beat a dead horse with this issue, but I'm in need of some advice from the Starcraft gurus. LOL
I am replacing the floor and transom of my 16' CC. When I ripped out the old floor, ofcourse all the foam was water logged. I plan on replacing it with the Blue or Pink stuff or maybe noodles or a combination of both. My question is how to lay it down? The original foam was mostly layed down length wise.....ok NP! But underneath that, were pieces running between the ribs side to side, laying flat against the bottom. It seems to me, that created a damming effect, not allowing the water to flow to the back. I also have some corrosion and pitting, mainly in the center of the V where these pieces of foam were laying, which I will go over with Gluvit along with the welding sticks that are used with a propane torch. I am considering just laying the new foam length wise on the ribs leaving the bottom open.
Am I correct or should I run side to side as well?
Thanks for the help!
