HorizonblueDK
- Joined
- May 27, 2010
- 355
The other day, my friend was having trouble starting his 4.3 engine. It ran a few seconds, died and there was a smell of gas. A day later, I tried starting it, and the same thing happened. Looking at the engine and yes, there was gasoline in many of the cavities on the intake manifold, so obviously, there was a leak. I had never thought that gas could pour out like that, since it is an overhauled carb I got from I-5 carburetors a few years ago and installed for my friend. I shouldn't have tried the second start..........Anyway, fuel lines were ok, so I took the carb off and brought it home with me.
I hooked it to a "facet posi flow" electric pump and started pumping. Gas was coming out many places, e.g. out of the acc pump. I assumed that the float was bend, so that the needle couldn't close properly. I took the top off the carb, to inspect, but everything looked fine, so I tried gently with compressed air, to recreate the problem. Once again, it was leaking I could hear, but suddenly the needle closed correctly, and no leak. After that I couldn't recreate the leak. I took the needle out, and here is how it looked. The tip is gone. Has anyone seen this before?
I'm having a hard time believing that the missing tip can cause the needle to not seat properly, but I have a new overhaul kit, so I will install the needle and seat from that kit.
Is flooding a common problem on Rochesters Q-jets?
