I am in the middle of rebuilding out 1999 Rinker 272 and i’ve decided I want to use Seadek for the flooring. However, the existing gel cost is worn through in a few areas from getting skis in and out as well and sliding the cooler in and out. What’s the current recommendation for a floor that will be 95% covered?
Thoughts:
Epoxy - durable but thinner than gelcoat. Will it last?
Textured coatings - easy to apply but creates problems for the Seadek adhesion.
Respray gelcoat - can match factory, but all the sanding and buffing to make it look good.
What are the recommendations? Did I capture the pro/cons correctly?
Thoughts:
