Greetings,
The 19' F/glass boat I am restoring was originally manufactured with a foam filled f/glass floor along each side of the bilge. At some time, and for whatever reason, the original floor has been cut out and replaced with 3/4" Marine (?) Ply. This plywood floor is rotted along with most of the ribs underneath it (see photo 1.) and I am now in the process of removing all of the ribs and timber associated with it. The ribs underneath were also made of plywood and were installed to support the plywood floor, they were glued to the hull and were reinforced with fiberglass strips. (see photo 2.)
If you look at photo 3. you will see that the original fiberglass floor had V-shaped supporting ribs running across but they did not extend down to the hull. So I am thinking that it is not necessary to go to the trouble of fitting new ribs.
As I intend to replace the floor with 1/2 Marine Ply I am thinking of gluing some 2"x1" timber to the under side of the new it as a kind of supporting frame, then screwing and gluing the new floor assembly into place. This way the floor becomes self supporting and does not rely on the hull.
I am wondering what others would do in this situation? Do you think that this would be a strong enough flooring method or would it have too much flex?
1.
2.
3.
Cheers,
bluey.
1.
2.
3.
Cheers,
bluey.
