Matrex
- Joined
- Aug 2, 2008
- 54
I bought my first boat this summer, a little 1985 Doral runabout. Well, I had no idea what I should be looking for when I bought it, and after reading many posts in this forum I realize that that spongy feeling in the back corner or the floor is probably not a good thing.
Well, this weekend I pulled off the cushion of the back seat (right side of the motor well) and see someone has cut a hole in the floor, maybe 6"x4"... i think they were probably trying to see what was down there too. What seems to be down there is totally rotten plywood. I can put my hands in and just pull it out in sopping wet clumps.
Having no prior knowledge of boats I am making some assumptions...
1) First step is to find out why it is so wet down there... no obvious leaks.
2) I assume that this rotten plywood mess I am finding is the actual floor and was under a top coating of fiberglass in the rear of the boat, and has rotted from the bottom up. It seems to go from just in from of the rear seat back to the transom on one side of the motor well.
3) Even though this rot seems to be on only one side, I assume this will likely mean ripping the entire floor, possibly fixing/replacing stringers, laying plywood floor (covered first, top and bottom with fiberglass) and re-glassing it to the sides of the hull.
3) If I reach in and double-joint my arm I can touch what I think is the bottom of the hull - at least it feels like fiberglass. Can I assume then, that there is no foam in this boat? I read a lot about it, but not sure what it really is (Styrofoam blocks?) or looks like.
Am I on the right track here?
many thanks
many thanks
