Re: top removal help
Here are some more photos, The top has got to come off and all the foam removed it is water logged. the stringers seam to be cut out for the boards that go from side to side whatever they are called they are rotten also. The floor in the back where the gas tank sits is shot on both sides. There is not enough access to repair properly,so the top has to come off.
The good thing is that I will have a near new boat for 800 buck not a bad deal.
What is the best way to remove the top. Crap I don't know how to disconnect the motor or remove it , I have a hoist but what do I hook it to. It is a 1975 Johnson 115 hp with power tilt.
Please help.
To remove the floor I cut 12" to 16" squares for easy removal, with my skill saw.
