rottenray6402
Ensign
- Joined
- Jul 27, 2004
- 923
I'm sure this question has come up many times but I seem to be having a problem with the new search feature since the format has been changed. Anyhow, I am replacing the plywood deck in my 92 Crestliner and am getting ready to lift the plywood. I found in the rear area foam that looks just like great stuff insulation so I anticipate finding the same stuff under the plywood. I know from reading this forum that some foam will soak up water and become saturated over time. My question is : will great stuff work for floatation, if the existing foam looks good should I leave it alone? If it is bad and great stuff won't work what should I use? Thanks! ???
