What do you mean by the proper BRP TNT fluid? Is that the kind it's supposed to take??
I think I have a leak in one of the gaskets because there was no fluid in it.
If there was no fluid at all, you have a fairly serious leak. Fill it up then cycle it to locate where you are losing fluid.
BRP= Bombardier Recreational Products, they are the new owners of Johnson/Evinrude from OMC. Just meant that it is the OEM fluid that you would get from your local dealer. If one is not close to you, use the ATF Dexron III available almost anywhere.
