Fluids for Glastron GXL 235 question
TXGlastron
Good afternoon. I’m still learning about my boat. There is a fluid reservoir I’m unfamiliar with. I see the oil and drive line lube locations fine. But, as I look into the engine bay, there is a reservoir in the far right that I don’t understand. Anyone know what other fluid I need to keep watch over?
Thank you
TXGlastron
Just to add, it appears this is the trim pump, but I’m not certain what fluid is required. Thanks again for any guidance
Merc power Trim and steering fluid or ATF with Mercon
TXGlastron
Thank you. Is that the same fluid that goes into the power steering fill? (I’m new to this boat still)
SAE J1171 is the standard for electrical components that are spark shielded to not blow you up.
