fluids
Anything special about 2002 Mercruiser 5.7 power steering fluid?- mine is low but has a warning sticker on the pump to "see owners manual" (which I do not have).. thanks.. also<br />Does anyone have the owners manual for this engine?
SS MAYFLOAT
Re: fluids
Hi Dave,<br />I'm not a 100% sure, but I know when I'm at a parts house, I haven't ever noticed different grades of powersteering fluid. I know for sure not to use tranny fluid, engine oil, and brake fluid. These are definetly fluids that can ruin you system. I would pick up the phone and double check with your local Merc rep and ask them.<br /><br />If it is low, you probably have a leak somewhere. Fluid just does not evaporate within a closed system. Remember OIL in the bilge is a serious violation if it gets pumped out into the water by your bilge pump. The fines and cleanup costs can be expensive enough to buy a new boat.<br /><br />Good Luck and welcome aboard :D
Re: fluids
Dextron II (ATF)..............<br /><br />Nothing Special............... ;)
djvan
Re: fluids
I think dexron 3 can be used in the place of dexron 2.<br /><br />DougV>
