Re: Flush Kit
they just look like clear plastic sticking up about an inch and half with a little rib around for quick connect flush hose to hook onto and has a red plastic cap to seal when driving. i would recommend getting the right ones off internet or dealer....should be fairly easy to get as when i went to buy my flush hose it was just for seadoo jetski. you dont want those hoses just laying in bottom un capped. and you can only run the engine on side your connectted to. and must follow this exact procedure....... START ENGINE,TURN ON HOSE........SHUT HOSE OFF BEFORE SHUTTING OFF ENGINE....any different way you will fill engine full of water. i bought a little inline hose shut off valve from home depot so i could turn on at house and be able to turn on and off while in boat.
