Flush kit
RichRab
Any opinions on the flush kits that attach to the rear of motor so you can flush the motor while the boat is docked. I have a 5.0 Merc alpha One Gen 2 that will be kept in salt water. The manifolds were new last season. Also any opinions on the additive Salt Away? Thank You, RR
jerryjerry05
Re: Flush kit
Definatly use a flusher.Never used Salt Away.
The worst thing is not flushing.Or draining and letting it set without any fluids in it.
Salt water makes it start to rust,fresh water will too.Just not as bad.But air will make it rust faster.
So leave it with fresh water in it.
Better yet.Add a closed cooling system.One that includes the manifolds.J
RichRab
Re: Flush kit
Anyone have any experience or opinion about the permenent flush kits?
jerryjerry05
Re: Flush kit
Sorry should have said they work well.By all means install one if your gonna leave it in the water.J
