Flushing a Johnson v4-100
Naslund
I usually trailer my 16ft Beachcraft, I am tired of the lines at the launch. I'm mooring it in a salt water marina for the summer. I don't have power tilt so the motor is either up or down. Can I still hook up the "earmuffs" and flush the engine while the motor is tilted up?
Naslund
WillyBWright
Re: Flushing a Johnson v4-100
I dunno, but I don't think you have much choice but to try. I think your main hurdle is going to be that the carbs aren't designed to run in that attitude. Look for a 1/8 pipe plug on each head. Perhaps you can plumb some fittings to do it statically using those as an access point.
F_R
You can tilt the motor, attach the muffs, and then lower the motor to run it. The muffs will be under water.....so??
tashasdaddy
as FR said, a lot of inboard/outboard people do it, and leave the muffs, and hose attached, until next trip out, they do that to try to keep as much salt water out of the lower, i think thats a wasted effort.
