Flushing engine to get antifreeze out of oil
jabfd
Hi guys I have fix me mercruiser 470 but I have some frothy areas in my valve cover
Is there some thing I should do before i launch the boat? I change the oil. Do I just run it a little then change oil again or do I use a flush in a bottle to help clean the inside of the engine ? I read of people using trans fluid but not sure what's best. Thanks again Jeff
Bt Doctur
Re: Flushing engine to get antifreeze out of oil
frothy?? if your seeing oil foam, then your mixing the oil and A/F. If you mean a whitish looking deposit in the rubber cap, that just could be some moisture
Ayuh,... What color is it,..??
How much coolant is it usin',..??
What did ya just fix,..??
jabfd
Hi guys I just fixed the cam seals . but I did have a lot of antifreeze in the oil to the point of when I pulled the oil plug at first only antifreeze came out then oil . So I changed the oil and new filter . Now I wanted to know. do I just run engine and change engine oil more often or is there a way I can flush it out to make sure the antifreeze that was in there does not damage any of the bearings thanks in advances
harleyman1975
Ensign
The damage may already be done... Not trying to ruin your day, just sayin'
jabfd
i hope not the engine is running fine no big knocking noises or issuse yet. thats why not sure if there something i can do to help protect the bearings from the a/f thats was there. is there any additives that could help thanks again
