Flushing engine
tcoat60
I have a 2016 Crownline 255 SS with a 300 HP Volvo Penta engine with 20 hours. While flushing the engine the temperature came up to 144 degrees and stayed there for a while and then dropped to 0 degrees. The engine was not running hot, has anyone see or heard of this issue before?
tcoat60
I was flushing it through the hose connection on the side of the engine. I have flushed it once before and the temp stayed at 140 thought the whole process.
Lou C
Either an issue with the sending unit or connection there, or the flushing unit is allowing air in, causing the sending unit to not read properly.
DouglasW
I can't envision this being anything but a problem with the gauge or sending unit. Zero degrees F wouldn't occur even with no water on the sensor unless you are in the arctic.
BRICH1260
I`d say a sending unit or gage issue. I`d start it up again and see what happens, monitoring the block temps with an IR temp gun. If temp gun indicated the block and manifold temps are steady, then it`s the sender or gage.
