I have read many threads about this. <br />Concluded that Perko Flush Pro is not something I would want to use. "West Marine customers" feedbacks are not that great to say the least.<br />MSD "Guardian" setup is close to $500 per engine, and I have two engines. Do not want to spend that much.<br /><br />I am going to go with brass open/close valves and hope that I will not forget to open it back once I flush the engine. I figured as I get older I may need to custom order a sign that would read "Close garden hose valve, Open raw water intake"
. But I think I am good for now.<br /><br />Here is what concerns me:<br />Water pump impeller is there in the outdrive to draw raw water into the cooling system. Having the open/close valve in the close position directly at the water intake hose will prevent raw water entering the cooling system of the engine (which is exactly what I need).<br /><br />Would this create a problem for the outdrive impeller
It will be turning and pushing the water into a blocked passage. <br /><br />Would this overheat the impeller housing causing damage to rubber impeller? <br />Anyone sees any issues having this setup for flushing?<br /><br />Thank you.
