Re: Flushing outboard at marina
Stalker.....You can use the backflush on the back of the motor with the hose no problem. I usually do it with the engine up, my boat is in a slip also and I don,t want to have the lower unit in the saltwater when I'm back flushing it. Do not run the motor when you have only the backflusher hooked up, the water pump will be running without any water to lube it and you will destroy your impeller. There is also another post on here (General Outboard) that talks about using the muffs at a slip. I believe you can just raise the motor, put the muffs on, turn the water on, then lower the motor back down into the water and start it to flush and I guess the muffs keeps the saltwater out of the lower unit. Personally I don't see any reason to use the muffs if you have a backflusher. Some guys say it won't flush as good because the thermostats don't open with the cold hose water, but I figure they designed it to flush so I'm sure it does a good enough job. I have had motors that I never flushed at the dock, only when I took them out for the winter, not that you should do this, but the backflusher should be fine, and yes you do use the hose at full pressure, at least that's what I do. Good luck.
