Re: Flushing Yamaha Motor
First a big WELCOME!!!!!!!! Now - I don't know your motor but most can be flushed with a thing that is called a "muff". It fits over the water pickup grid above your gear case. You attach a hose to it, turn the water on and start the motor. Don't run it over around 1,500 rpm. Run for 5-10 minutes.<br /><br />No need to flush at all if you run in fresh water. If you run in salt flush it at the end of every day. I (run in salt) take the cover off and spray some WD40 or whatever you prefer.
