Fly Wheel Help
debt finder
HI I JUST PUT IN A NEWER 350 , WENT FROM A 2PC REAR MAIN TO A 1PC . NOW MY FLY WHEEL AND COUPLER DON'T FIT .:mad: FOUND NEW COUPLER THAT WILL WORK BUT THE ONLY FLY WHEEL I CAN FIND ,THAT IS THE SAME DIA. HAS 10 TEETH LESS :confused: DOES ANYONE KNOW IF THE FLY WHEEL WILL WORK ????? also could anyone tell me the differance between a flywheel and a flex plate ? thanks for your time
Re: Fly Wheel Help
That's Impossible.......
Chevy use only 2 different diameters,....
The 12" with 153 teeth, that uses the straight across bolt patterned starter.....
And,....
The 14" with 168 teeth, that uses the staggered bolt pattern starter......
You need a Flywheel,.....
Flex-plates are used with automatic transmissions,+ some Inboard transmissions.....
Btw,....... Loose the Cap-Lock,....... It's irritating,+ Hard to Read......
bomar76
Re: Fly Wheel Help
1. You need a 1 piece flywheel with the correct 3" bolt pattern.
2. You need a 14" flywheel.
3. Flex plates are for automatic transmissions, so unless you have a automatic tranny in whatever it is you have, you need a FLYWHEEL.
4. You need a coupler to fit a 14" flywheel.
bomar76
Re: Fly Wheel Help
sorry, Bondo, we somewhat overlapped....
Lakester
Re: Fly Wheel Help
HI also could anyone tell me the differance between a flywheel and a flex plate ? thanks for your time
hello,
the flywheel stores crankshaft energy to drive the driveline. a flex plate (thinner and lighter) is similar, but it is designed to attach the torque converter to crank, which is heavy and similar in wgt to a flywheel and does same thing other than what the torque converter does, being that it is a t conveter. it works similar to a clutch but is hydraulic vs manual.
hope this helps some...
regards
lakester :cool:
