fly wheel puller
mikeaga
Do I need a fly wheel puller. Or can I use a harmonic balancer puller on a 1976 4 hp johnson?
AlTn
Re: fly wheel puller
harmonic balancer puller should work fine
Rick.
You should use grade 8 bolts if you can get them. 1/4 inch standard thread. Best of luck. Rick.
dodgeboy1979
on lots of good penetrating oil, put pressure on the puller and spray with oil and let it sit, i found sea foam makes a good penetrating oil that seems to stick.
kfa4303
Banned
+1 of the GRADE 8 bolts and washers. You should be able to get them at any Lowes/HD. Here's a handy pic of the puller in action.
