ReefRaider
- Joined
- Apr 14, 2009
- 30
Is it possible for something to get into the flywheel enclosure area? 1993 5.7 Mercruiser. Engine is "tight", starter sometimes turns the flywheel, then almost seems to catch and have problems. Flywheel of course entirely surrounded by "shroud", can only see teeth when I pull the starter. Lot's of grease in that little opening and did pull out some small debris including fish scales! (I have no idea) Can't turn engine by hand, even with plugs out, to see all the teeth. So, is it possible something could be in that flywheel enclosure (shroud?) area and jamming it up? Is the only way to access that area to pull the motor? Thanks in advance.
