Ok I'll drop the lowerunit on saturday morning .It's seized? You have to determine if the seizure is in the gearcase or the powerhead. If it's the gearcase, the flywheel should be able to rock back and forth a tiny bit. But it still might if it's a powerhead seizure, so the only way to know for sure is to remove the gearcase.
sounds good, but what's pb blaster? I put marvel mystery oil in it 3 days ago and have not touched it since.i just unfroze a 15hp evinrude thats been frozen for the last 4 yrs by spraying pb blaster in the cyl's and letting it soak for a week and half....every couple of days i would go out and try to turn it ...finally it did...still got decent compression on both cyl's...i'll find out tonight if it runs..then i'll decarb it....try it out..its worth a shot.
