d_glover25
- Joined
- Mar 7, 2007
- 47
I recently pulled the flywheel on my '56 12hp Gale and found out that opening on the flywheel is verry stuck to the crankshaft. Stuck enough to break the cast metal flywheel and leave the steel insert with the threaded holes for the puller still on the crankshaft. The three bolt puller I tried after I broke the flywheel, pulled the steel threaded tab up until it stripped the thread and bent the tab about 30 degrees. How can I get the remaining piece of flywheel off without damaging the coils or points? Did I do something wrong?
D
D
