Hi there, I recently brought my 1987 Evinrude 225 (runs great) in for a tune-up and the techs wouldnt do WOT adjustment due to the fact that they noticed that three of the flywheel magnets were bunched to one side. I was quoted in excess of $2k for a fix with new flywheel. instead I spent $50 on a flywheel puller and a few magnet repair kits. I pulled the thing, removed the loose magnets, and sanded away all of the old epoxy. then I decided to remove the other magnets as well. I tapped them with a screwdriver and they popped out. great. no problemo- I am also replacing the stator, since one of the coils on the thing is blackened to bare wire.<br /><br />my questions: I took care to look at the magnet orientations before I took it all apart: three were oriented to one polarity, as marked by the little notch in the corner, and the other three were oriented the opposite polarity. as far as I can tell, someone before me did a home-made job of the same thing, since epoxy was slopped all around. (this is why I took out the three that were still attached) when I place the magnets back into the flywheel with the proper epoxy, do I place them in exactly the same orientation? that is, are the polarities supposed to alternate as you go around the flywheel, or are they divided 50/50, with three magnets on one half of the flywheel at one orientation, and three magnets at the other half the opposite? further, does the orientation matter relative to any particular point on the flywheel? <br /><br />I was planning to just glue them back in at the same orientation and polarity as I found them, but it occurred to me that the guy who did this last might have known even less about it than I do. the only complaint I have about the running of my motor has been weak charging of the battery, so I am hoping that the magnet fix and new stator will do the trick. is there anything I should watch out for in re-assembly? be sure to use locktite on the stator screws, etc? further, could I have ruined my magnets when I whacked them to get them out of the flywheel? they seem plenty magnetic still, but I am thinking of replacing them all since I have it apart. last thing, should I have it balanced?<br /><br />thanks in advance for any help, and all best regards.
