Re: Flywheel Position
Does your flywheel have advance and retard degree markings on the edge, kinda where a rope would go if used to start the engine? If so, remove spark plug from #1 cylinder and find Top Dead Center as close as you can tell. At this point the pointer should be pointing at about 0 degrees on the markings. My engine has a movable pointer and I have to use a dial indicator to locate the exact point for timing to be accurate, but this will be close enuf to determine which holes to line up for flywheel placement. Any others with more info are encourge to chime in. JH
