Flywheel Puller, Motor liftint eye.....
mrmelrod
I'm in dire need of a flywheel puller for a 2006, 4 stroke 75hp outboard....its a triangular shaped apparatus with the puller lifting eye in the middle, and a 3 bolt triangular pattern on the outside....the cheapest I've been able to locate (ebay) is about 225.00....any suggestions would be greatly appreciated.....thx!
Prophammer
Re: Flywheel Puller, Motor liftint eye.....
Have you tried a harmonic balancer puller, available from local autoparts store? I think they are cheaper than $100.
dunc333
yes the harmonic balancer kit works they are about $30 in australia.
i used a steering wheel puller on mine 20$ at your local auto store.
birdleg81
The typical crows foot pulled should work, just like the one in the link. Can be had for around 20 bux for a cheapie.
