flywheel removal . can you lift and just turn engine
delsol
got a 5.7 89 . i only have a car engine lift. boat has a rear wing. teeth are bad on flywheel. car i just lift engine spin it sideways . put on flywheel and reinstall. can it be done. 89 glastron w/ 5.7 alpha 1 . i think i got the room. but i am asking..
bob
mkast
Re: flywheel removal . can you lift and just turn engine
Sure, if there is room.
Ayuh,........ Then I guess it's worth a Try.................
Are you going to do Just the New Ring Gear,..??..??......
delsol
hi bondo i am just thinking to buy flywheel here is a picture of engine..i have no big hoist but can get something to turn engine. do you think new flywheel $150-$200 from ebasic or ring gear from them $40.
i think i got plenty of room...would it best best to fix first to winterize..i got alot done this year...if i can get a hoist it will be easy imo...i am thinking new flywheel as i can just r+r it
bob
For the $160.00 difference,........
I'd rent a Garage for a weekend............................:rolleyes:
It's a realitively Easy job swapping the Ring Gear..........
Once the Flywheel is On the Bench of course.......................................:)
delsol
thanks bond-o
bob
