I have an '86 rude - 140 HP. After running a lot tests I have determined my cylinder firing problem (both on port side of engine) must be caused by a faulty stator or trigger. I need to remove the flywheel to check things out. I have ordered a harmonic balancer puller which should do the trick. How careful must I be in the removal and re-installation ? Does the flywheel position have to be marked before removal ? Anything cleaned or re-greased ? Also, can you replace the sensor coils separately or do you have go for a new timer base ? Thanks.
