Re: Flywheel Removal
Busboy, I have taken off my 1977 Merc 1500 flywheel several times, by myself, using the wedge and tap method. It wasn't too hard. The flywheels are flexible (stamped steel). If yours is really stuck, take off the nut and washer, put some penetrating oil onto the spline, put the nut back on upside down (or ger a regular nut), even with the top thread. Now get a friend to pry up on the flywheel's edge and you do the same on the outer side, and tap the flywheel nut. It should break loose. This ain't no Johnson motor after all, those never came loose!
