Working towards rebuilding power head pistons, rings, bearings, etc. ... on a 94 Johnson 115. Removed pretty much everything off the block heads, carbs, intake, wire harness, and got to the flywheel. Use strap wrench and 1 5/16" socket on breaker bar to remove nut. Quite a battle but the nut came off. Now I've placed a standard puller (three bolt) on the crankshaft and flywheel and cranked down pretty heavy the thing won't budge. Can I use heat on the crank or flywheel to release? Any suggestions would be appreciated.
EJ
EJ
