Re: Flywheel removal
go to O'riellys auto parts or autozone, get a harmonic balance puller, cost is $7.50 plus tax. Then go to home depot or preferably lowes(better assortment) and get grade 8 bolts to use. It is probably a 1/4" hole with a 20 thread per inch bolt you need. Using cheap bolts will just strip when tension gets hard. It takes some time and eventually it will "pop" off the magneto. Just make sure the puller is parallel to the flywheel when you start or it will go off balance and bend bolts somewhat
