Hello forum,
I have a 1986 125hp Force. It backfires when I try to start it when its cold so I re-checked how to set the timing and found that I did it wrong. This is the way I set it first, I started the engine & let it idle, set my flywheel zero mark right on with the timing tab mark. After reading my book, I found that this is wrong. It says to put the boat control in forward gear & at full throttle, have someone crank the engine over (dont let it start) and set the static timing to a maximum of 34 degrees BTC. Well I have 3 marks on my flywheel that are not marked so I am not sure which one is right. There is a formula in my book on how to lay out an unmarked flywheel and when I applied this formula to my flywheel, it comes out to the furthest mark from the zero mark should be the right one. The problem with this is that I guessed that the closest mark to zero was the right one and it started right up with no backfire. I then read into it further and found that by using the formula, I was on the wrong mark so I re-set to the furthest mark and it backfired. Could have been alot of fuel in the cylinders from all the cranking over i guess. Anyone know which mark is 34 degrees???
Thanks,
Thanks,
