Flywheel ?
oxmax360
Hi all just changed stator and trigger week ago, took boat out today and it started making a rattling noise, shut her down popped open the crowl and i could turn the flyweel nut by hand, i torked it to 90 lbs when i put it back on?, troll motor back to dock, got her home retorked it ran it on the hose did it again, what am i doing wrong? Maybe did not do it right, should i use lock tight, also i did not need to use the wheel puller to take it off 2nd time.
SkiDad
Re: Flywheel ?
is the key still in the drive shaft ?
jerryjerry05
Re: Flywheel ?
What we working on??
Does the nut still have the nylon insert still on the top of the nut?
If it's been removed a bunch of times it might work loose??
Never had that problem before. F1968
FLYWHEEL NUT(depending on the model???) $11.06 $7.74 Still available at boats . net
oxmax360
Re: Flywheel ?
1989 125 force, i think the nut is missing the nylon insert,
