Re: Foam, 2lb or 4lb?
I used 4lb, under a 3/4" deck. It's going absolutely nowhere.. solid. Under 3/8 you're going to need structural foam, as there's no way 3/8 ply will properly support weight without it. That means 4lb at a minimum. 2lb is not structural rated, is only "resistant" to water, and is basically made for filling cavities that bear no weight, and gunwale or above deck applications.. not to mention foam in place packaging. <br /><br />Were it mine, I'd use 4lb, or I'd spend the $ in ply and upgrade to 1/2" and then possibly go with the lighter foam. That would be your cheaper option I'd think. <br /><br />-Roger
