Re: Foam Below Floor
Howdy djohns19,<br />In a perfect world, the foam wouldn't absorb water w/out the skin. The trick is, it ain't a perfect world. All the horror stories you here about ureathane foam acting like a sponge are true ONLY if the mix ratios aren't followed precisely. If the instructions say 1:1, it has to be 1:1. That little bit that sticks to the inside of the "A" container, when you pour it into "B" is enough to screw up the ratio and the results is open-cell foam. Then, of course, there's the mixing. We used a helical mixer turning about 12 grand to mix in-place foam. I don't know what foam you're using but I would be real careful to seal it with fiberglass all around the edges and take all precautions to keep it in a water-tite enclosure. A friend of mine used empty plastic bottles to take up space in the area he was foaming, using less foam and accomplishing the same thing. It worked.<br />Anymore questions, lemme know.<br /><br />c/6<br /><br />hooty
