Mark20Twain
- Joined
- Dec 28, 2007
- 5
I have a question about an option on replacing my boat floor. I am thinking a lot about wood rot after having to replace the transom and the floor stringers and want to do a foam floor. The boat is an old 1989 Mark Twain 20? really it is 21? but that is what it is titled 20?. I have replaced the transom and the 2 stringers it had 2x6x11 running the length of the floor. I replaced it with 2x8x11 knowing I wanted to notch the tops every 12?? to fit and run a 2x2 across the width of the boat to strengthen the floor. What I want to do with the foam is Home Depot and Lows sells 4x8 foam sheets 2?? thick and I want to cut them to fit the floor in the boat and then pull them out and lay them on the floor. When they are on the floor I was thinking of flipping them over and glassing them together on the bottom. After it is dry take the whole floor about six foot wide and twelve foot long now after it is all glassed together and put the glass part face down in the boat. Now I will have just foam facing up where I will glass tape the sides then multiple layers of glass for the floor. Well I made that sound easy hahaha lol? I know this can be done and all i'm just wondering if you think my big *** 240lbs stepping in and out of the boat and my weight on the floor would wear it faster than me just using ? or ? inch plywood 4x8 for the floor. The weight difference would be juristic verses using wood about 200 lbs. I would love to hear feedback
