Re: Foam holes?
Welcome to iBoats!!
Well now that's a horse of a different color. You didn't say that in your first post. You just asked what to do with the holes!!!! If the underlying foam in your boat is wet, there is NO method that I know of that can dry it out. It will have to be removed. You can removed specific sections if they are the only ones affected or if it is the entire boat then the entire deck will have to be removed to remove the foam. If you do a search here on the forum for wet foam I'm sure you will find PLENTY of examples of how others have dealt with this problem
