Re: foam in a capri
ok so i got a 85 bayliner capri 1950. im wondering why there is foam up under the lip of the hull
USCG reg flotation foam, structural rigidity of the hull
i removed the wood around the engine and there was foam on both side of were the rear seats were up next to the hull so would like to know what the foam was there for
Same as above, plus if near the engine compartment of an I/O motor, sound deadening
and should i replace it when i put new wood back in
It is advisable to replace all the foam you remove, flotation & the additional structure it provides reinforcing the strength of the glass hull
also if so what should i use it just looked like factory spay in foam
The 'spray' in foam used by the factory to build your boat, is NOT the same canned spray foam available to you, anywhere. 2 part pour in foam is your best alternative, it is available from many vendors, here is 1.
US Composites is often the low cost, best service vendor for the glassing supplies you'll likely need as well. But that is all fairly far down the road from here. Spend some time reading thru some of the threads on the
Boat Restoration, Building, and Hull Repair forum's homepage. Search for WoodOnGlass, oops, friscoboater threads on the work they've posted. They are all invaluable resources. oops hull extension thread has an index on page 1 to help locate info quickly in his HUGE thread. Friscoboater has lots of great info in both of his threads, a YouTube channel & blog that are also excellent resources. WoodOnGlass has extremely helpful diagrams of how to put back stringers, deck & transoms. Don S's
how to's are also a good place to find info. Frisco & oops are both in that list of tips.
There is lots of good info around, look thru some threads & do some reading. You will find lots of info & many answers to questions you are not yet aware that need to be asked.
In fact, at the bottom of your thread, there are 5 threads the iBoats server lists as similar to yours:
- spray foam versus pour in foam?
By sabbath20 in forum Boat Restoration, Building, and Hull Repair
Replies: 4 Last Post: May 18th, 2012, 03:18 AM
- Computer Packing Foam for Foam Replacement?
By nhangler in forum Boat Restoration, Building, and Hull Repair
Replies: 26 Last Post: May 31st, 2011, 12:50 AM
- 1988 bayliner capri 15 footer deck and foam replacement
By Eaglewings05 in forum Boat Restoration, Building, and Hull Repair
Replies: 27 Last Post: April 25th, 2011, 11:11 PM
- Bayliner Capri new foam dilemma
By petermarcus in forum Boat Restoration, Building, and Hull Repair
Replies: 10 Last Post: August 9th, 2010, 08:54 PM
- replacing foam... yet another foam question...
By wca_tim in forum Boat Restoration, Building, and Hull Repair
Replies: 3 Last Post: February 8th, 2008, 03:08 PM
Scan thru them, you may find useful info in them as well.
Best of luck, and start reading. You will have some work ahead. A through inspection of the hull, deck, stringers & transom are all recommended prior to beginning reconstruction. Some of that inspection may involve opening holes in the deck & bilge, as well as some test holes getting drilled in the transom.
If I am not mistaken, this vintage of Bayliner was not known for exceptional attention to detail, nor close quality control, at the factory. So don't be surprised when you find some unexpected problem areas. They can all be fixed, and the crew here will gladly help.
By the way, you can not post too many pix or too many details about the areas in the pix. Use a photobucket account & paste the codes, it will give you pix like this:
[IMG]http://i1246.photobucket.com/albums/gg618/jbcurt00/other%20people%20boats%20or%20pix%20info/pic1124-5.jpg
Welcome to the dry dock
