Foam in carburetor
$richmillion
I have a 03 30hp johnson (jm30stls) it started getting a white foam in carburetor and cutting out to point of shutting off. Checked for water in gas both cylinders have 120psi compression. Foam want show up when running on muffs. Thinking maybe head gasket any help would be greatly appreciated.
dingbat
Foam in a fuel system is typically air leak on the suction side of the fuel pump.
dingbat
It looks like water checked all conections on fuel pump and all are tight. With cowl off its blowing "foam" out of carb
“Tight” doesn’t mean a thing to a vacuum side leak.
How does water get inside a carb from the cooling system? It doesn’t
If indeed it is water, you have water in your fuel tank or filter/seperator.
Collect the “foam” in a jar and let it settle out.
Grub54891
Is this a four stroke? If so did you check the oil to see if it's milky?
$richmillion
No water in tank drained tank and put new gas in does same thing
F_R
Exactly where are you seeing this foam? In the float bowl? In the carb throat? Hard to imagine it right now, but is the weather cold? Humid? Location?
It is condensation!---Fuel evaporating needs heat.-----So the carburetor body get cold.----Moisture condenses and fools you that there is a problem.-----Small aircraft have a " carburetor heat system " and you must wonder why that is.----It prevents icing !!!!
oldboat1
You might try drigas (or similar) in the tank to control the condensation, just as you might for an icing problem.
F_R
Similar to refrigeration systems. Carburetors get cold due to expansion. The water condenses from the air. That's why I asked about the temperature. In a prior life, (in the Army) I had to keep a generator running in cold weather. That sucker would ice up and quit if I couldn't figure out a way to keep the carb warm.
oldboat1
gas evaporates quickly, cooling carb and metal fuel lines or connectors. On a summer day, that means condensation. Condensation is water, which doesn't burn worth a hoot.
