Foam, its dry. Leave or remove?
BigB9000
Pulled my deck, and the foam under it is very dry. Should I yank It out anyway, or leave it be?
maxum247
Re: Foam, its dry. Leave or remove?
If you've done some core samples and are certain the foam is dry thru and thru you can leave it. Unless it will be in the way of your work, then you would need to remove it and replace when done. What type boat you working on anyway?
oops!
lucky stiff...!!!! :D
do core samples in different places of the foam.........then do samples on the stringers....if the stringers are dry....and the transom is good....button it up and go fishing .......
lucky stiff....
ne7800
lucky stiff....
i would do what ever oops says he is the guru of restoration lol
BigB9000
Center stinger is the only rotten one. And thats only for 2" in the center where someone screwed something down. The deck had 4" rotted holes all over it, again from someone screwing stuff down.
tashasdaddy
sandwich the center stringer with a piece of 3/4 ply, on each side, so it laps both ends by atleast 2 ft, glass it in, and put the deck on it.
BigB9000
Glass?!?!?! Awwwww, this boating stuff is getting harder and harder.
.....damn fiberglass
oops!
itch itch itch....:D
