Re: Foam Removal
Jim, Rmoval of the foam is not hard, however, sometimes the foam supports the "V" part of the fiberglass hull. Also, the foam is required to float the boat if it fills with water. Here are some suggestions.<br /><br />If you dig out the foam to make the opening for the cooler or livewell, only dig out enough foam to make the well have a flat bottom. Now cover the remaining foam with fiberglass cloth and resin. The remaining foam, held in place by the new fiberglass work, should still support the sides of the hull. Also, try to replace the foam you have removed somewhere nearby, to preserve the original floatation.
