Barley109
- Joined
- May 3, 2003
- 11
I believe that the foam that was pumped into the boat at point of manufacture clogged up what looks like a drainage hole in the front of the boat. It stops water from draining to the rear. I believe this is the reason the front deck was rotting out. I am now replacing 75% of the floor boards and decking.
Should I cut some of this foam out to make a pathway for the water to drain when it reaches the height of the hole? See pic below.
