Re: Foam under deck?
After reading a vast amount of information on this board, and just asking marines what to really do.....Frankly, my opinion would be (as what i have every intention on doing) Putting in the new floor, glassing the corners, bc i ripped out all the glass that was holding the wood in. Putting holes in the sub floor using a hole saw..(i used ACX from HD, 33 bucks a sheet..couldn't go wrong, it will outlast the length of time i anticipate owning the boat), that way i can replug after the foam expands.
Im not an engineer, and frankly engineers are just all books and it "looks" good on paper, but, i do believe the foam does create a structure support/pressure between the thin fiberglass bottom, and the thick floor on top.
If you read every post on this forum, about rotted floors, wet wood, damp transom's, everybody's direct advice is to rebuild it new.......toss your boat out if that's the case.
