Re: Foam under wooden flooring??
Blobs of foam on a metal boat floor. Never.It will help the boat turn upside down. Not good. Does the boat have foam from the factory under the seats, bow or the upper transom area. Check it out and post the areas. Sounds like a jury rig floor job.Right way is to put the plywood piece on the floor and block or shim it up to what you like. Measure the gap every 6" . You can now make curved pieces of wood to support the floor boards. Make the 2 end curves first, you can make curved supports for about every foot easily. You should be able to run electric cords NOT WIRES or anything else under the floor boards with notches cut into the curved supports. A squirt of Silicone Rubber will keep them in place on the floor. Not factory, but serviceable. If you clear the ribs by 2" no sweat
