Hello all,<br /><br />I winterized my engine yesterday.<br /><br />I have a 1985 Johnson 150hp V6 - fuel injection removed.<br /><br />I removed the carb cover and with the boat running I began to spray the fogging oil in. Low Medium Idle as the Can said. The engine began to produce an enormous amount of smoke as expected. And it began to cough and sputter a couple times but while I was trying to suffocate the engine by spraying into all of the carb intakes (3 carbs - 6 intakes) it would always come back and start idling normally. So I lowered the idle to low idle and tried somemore. A couple of times I thought that it might be near stalling but somehow it always kicked back in. I eventually killed the engine with the key while spraying the Fogging Oil in as I was runnning out of a full can of Oil and knew that I did not want to leave it running after I ran out to let the oil work its way out of the system.<br /><br />I finished up winterizing the engine and said good enough (it was my first time ever).<br /><br />Should I try again next weekend? Any advice?<br /><br />Unfortunatly my enigne is not quite this tough normally out on the water!<br /><br />Thanks.<br /><br />Todd Lynch
