Fogging through carb without starting engine
jmark
For various reasons I do not have access to my truck for towing my boat trailer for the next two months so I need to finish winterizing my boat at the storage site where I keep it. My question is can I fog the cylinders through the carb by turning the starter over (disconnect the coil wire) and try this for 5-7 second intervals, 4 or 5 times?
I still plan to pull the plugs and spray fogging oil directly into the cylinder also. I do not have access to running water at the storage site so I cannot start the engine (5 liter mercruiser, 199 Alpha 1) on muffs with a hose.
thanks for any response,
Don S
Re: Fogging through carb without starting engine
No, it won't have enough vacuum to pull the fogging oil into the cylinders. Just squirt some in the cylinders and crank the engine over a few times and put the plugs back in. You will be fine.
Haut Medoc
That would probably work.....
You could make a portable water source out of a 5 gallon bucket, a hose & a plastic gate valve that costs about 2 bucks at Home Despot.....
Just sit the bucket on the swim platform & gravity will do the rest.....
Just be sure that you don't run out of water, while the engine is running......JK
