supagidget
- Joined
- Jun 13, 2011
- 36
I checked the compression last night. I had 105 psi in each cylander on a cold test and water was coming out of the exhaust the last day it overheated. So I think the impeller was properly installed. Could the thermastat be stuck closed preventing water from circulating around the head? I read that you should replace the thermostat and the pressure release valve after an overheat. Just looking at where my thermostat is I can tell it wasn't even checked.
I read some other forum posts about the t-stat and the water cooling system on my motor. It said when the t-stat is closed only a mist will come out of the exhaust but when it is open you will have a greater amount of water in the exhaust.
The motor rarely if ever has more than a mist. I live in Florida and the water temp is currently 88. The motor does seem to cavatate a lot on plane.
It's a mystery but I am going to replace the t-stat tomorrow. Any tips?
As for the garden hose test to see where the water is ciurculating, after dreopping the lower unit where would I connect the hose and where I am looking for water circulating.
I have the original flush kit for the motor, so no muffs here. The guy I take my boat to is a genious with old johnsons and evinrudes. I just don't see how he could say I need a new powerhead without even looking at the motor after the second overheat.
I think he may want to play with his own motors instead of mine...
Ashley
