fone_man I got the info you wanted
stagger43
04003 717338<br />and it is stamped a DT 40.<br /><br />Whay year? Oil mix? 100/1 or 50/1.<br />If you mix oil with gas than what about the oil injection on the motor?<br />Thanks for all your help!
Pursuit2150
Re: fone_man I got the info you wanted
Don't know a lot about Zuki'S. I believe they started in the marine industry in 1977. Try calling the company direct.
alcan
HI Stagger 43<br /> I am not a suzuki man, but I'll offer some generic imfo. Water presure to the ear muffs? Just open tap enough that water squirts around them a little. Don't run your engine over an idle w/o a load. I wouldn't run less than 50/1. Yes there should be a good amount of oil coming out exhaust. I would also sugest the purchess of a repair manual for your engine. It will save alot of head aches. Hope this helps. Good luck.
fone_man
Need this info so I can help you...<br /><br />Have the following information available:<br /><br />Model number of your outboard - (DT 75 TCLH) <br /><br />Serial number - six digits stamped into the I.D. plate on the clamp bracket. <br /><br /> :cool:
fone_man
1987<br /><br />04003-714001~820015<br /><br />DT 40 MCSH<br />DT 40 MCLH<br />DT 40 CRSH<br />DT 40 CRLH<br />DT 40 TCLH <br /><br />A. Pre-mix Normal Service 1986-99 100:1<br />B. Pre-mix Severe Service ALL 50:1<br />(First 5 hours, 25:1 ratio)<br /><br />8-140 hp Injection 1980-99<br />(First 5 hours, 50:1 ratio premix plus oil injection)<br /><br />Hope this answers your questions.<br /><br /><br /> :cool:
