foot removal
ibgood
i have a 1994 evinrude mod. #E30RERM, which is a 30hp. my water pump seems to need replacing, but im having trouble removing the lower unit. i have no manual but do have one ordered. any help would be much appreciated.
v12mac
Re: foot removal
Do a quick serch for 30hp water pump and you should find some good stuff. Water pump replacement is usualy very straight forward. <br /><br />The standard gotcha for a first timer is allways the shift rod disconnect and forgetting or overlooking bolts.<br /><br />Mac
seahorse5
Re: foot removal
The shift disconnect can be accessed by removing the 2 plastic water intake screens and by using two 1/2" open end wrenches.
ibgood
Re: foot removal
thanks for the help, was able to remove foot and replaced water pump. but now as before, still no water coming out of the pisser. any ideas? i know the rubber tube that goes from the engine and thru the cowl is clean, cant even get a drop of water out the pisser.
bassnva
Re: foot removal
It could be the water pick-up clogged up...I had this to happen on my 150.
jimalsk
Re: foot removal
Have you pulled the thermostat? It may be clogged with gunk. Is the fitting the pee tube hooks up to clear? Can you back flush the motor? You may have to pull the foot again and see if the key for the impeller is on the shaft.
