they will work franki. ive done it atime or two. get a sending unit& gauge, Ive got an old aluminum street sign that i use for making the brakets. depending on the size threads on sending unit, cut strip off the sign long & wide enough to make braket in the shape of of an L with a backwards leg at the top also. on one end drill hole to bolt onto waterjacket head plate the other end drill hole just big enough so that sending unit threads will self tap. configure brakett so that when bolted to head the sending unit, when screwed in will bottom out on top of head. after all is said & done you will have to read gauge when engine is warmed up & running normal this reading will be your happy medium it works great if you can decipher my descrption. the last one i did was on a 1963 v-4 johnson. goodluck
